Topic: Latch talkback via ARC ?
This may be an RTFM question, but Is there a way to latch Talkback via ARC?
I know you can do it in Totalmix but I would prefer to do in via ARC.
A sugestion would be that a double-click on the ARC would latch the talkback.
Best
Eric
Re: Latch talkback via ARC ?
You can change the behavior in the ARC & Key Commands menu of TotalMix. By default it's PUSH (hold for talkback) but you can switch it to TOGGLE.
Thanks, I will check it out!
