1 (edited by RMEfanboy 2023-02-24 07:36:30)
Topic: UFX ii, How to connect SPDIF right!?
So, I will be as precise as possible.
1. I am planning on connecting SPL Machine Head gear with Spdif In/Out.
2. UFX ii does not have Spdif coaxial in/out so I googled around and found out that I can 'set' ADAT 2 in/out as SPDIF and use cheap converter to do so.
3. So, I bought, bi-directional something like this
https://www.aliexpress.com/item/1005004 … ainProduct
4. Bought 2 x Coaxial RCA cables
5. Connected like this:
ADAT 2 out to Toslink In
Coaxial Out to SPL Machine Head Spidif In
Toslink Out to UFX ADAT 2 In
Spidif Out of SPL Machine Head to Spidif In of digital audio converter above.
Now, What am I doing wrong?
Because, first of all I set it like this:
Input Options:
Word Clock Termination Ticked
Optical 2 In : SPDIF
Output Options:
AES Format: Professional
Optical 2 Out: AES/SPDIF
Clock options:
Sample Rate : 48k
Clock Source: AES or Internal (shouldn't matter right..?)
Now, I am monitoring AES in and I am hearing the exactly same sound without any SPL Machine Head FX,
even though the gear shows meter of Driving and healthy saturation...?
AES/EBU connection was very good no issue at all.
I am sure something is wrong here, in between right?
haha.. did I buy wrong digital audio converter...?
*Also I am using AES for Genelec monitors but with UFX ii, do I only get one of AES or Spidif but not independent use of it...? if I am correct...??
Because on Totalmix, I can never find Spidif channels.
Re: UFX ii, How to connect SPDIF right!?
Answered in the other thread.
