1 (edited by en5ca 2023-02-26 02:56:19)
Topic: TotalMix channel numbering on higher sample rates
Hi! I understand channel count for digital interfaces cuts to half if I double sample rate. With RME UFX+ MADI I get 1-64 channels at 48, 1-32 at 96 and 1-16 at 192. This makes sense.
But at 192, the channels for output are shifted to channels 5-6. RME driver also shows 'WDM buckets' of 8 channels, but Windows only identifies the MADI '8ch buckets' as 4 channels.
Is this how it's supposed to be? I would like to make a configuration, where the 'main' MADI channels are always 1-2, like for ADAT for example.
EDIT: Ah, there's a global channel count/numbering offset when changing sample rate.
