Topic: [Solved] TotalMix FX GUI/ DSP not showing on Windows 10 (HDSPe AIO)
Hey there, my total mix fx gui is not showing up on windows 10, I can right click it on the task bar, same with the DSP. I can exit it, click on settings. But nothing shows up.
Also device manager seems to not be showing the HDSPE-AIO.
Tried re-installing drivers, restarting, nothing works.
Any help would be greatly appreciated.
2 (edited by ramses 2023-03-06 16:33:45)
Re: [Solved] TotalMix FX GUI/ DSP not showing on Windows 10 (HDSPe AIO)
You mean the HDSPe AIO not the AIO Pro?
The device needs to be recognized by the proper driver, otherwise TotalMix FX will not start.
Which driver did you install? driver_hdsp_win_440.zip?
If yes: which CPU and mainboard do you have and into which PCIe slot did you install the HDSPe AIO?
Did you already try another PCIe slot?
BTW .. which version of Windows 10? Home, Pro? 32 or 64bit? 22H2?
Please add this information into your forum signature, best as "one liner" to save vertical space in the browser.
Then the info is already there for the next time.
Nevermind, I didn't put it right into the PCI-e slot so it wasn't detecting it properly.
Thank you
Did the card already run in this system? Or did you just buy from used market?
Check proper placement in the PCIe socket.
Check carefully the PCIe cards pins, do they need (careful) cleaning?
