Topic: MYTEK 8x192 with DIGIFACE USB
Hello dear RME Forum,
I have a question regarding the following situation:
I would like to run a MYTEK 8x192 converter with an RME DIGIFACE USB.
The connection should be made via ADAT I/O on both sides.
Since the MYTEK 8x192 has a headphone output as well as the DIGIFACE USB, I would like to know if both headphone outputs can be used simultaneously in this consellation?
The MYTEK 8x192 has a stereo monitor OUT, can I still use this as a monitor out in this constellation and adjust it via the MYTEK output control.
I would be very grateful if you could share your experiences with me.
I would like to use 2x headphones without an additional device and at least 1 pair of monitors, as a controller I could alternatively imagine an RME ARC.
I would be very pleased about further suggestions.
Thank you very much in advance.
Re: MYTEK 8x192 with DIGIFACE USB
Hi
Yes, the headphone output on the Digiface USB has its own channels (going to DA-converters), it’s separate from all the ADAT channels. Of course you have to do the right routings within Totalmix…
