Topic: Beyerdynamic DT 990 Pro - correct setting
My current headphones are the
Beyerdynamic DT 990 Pro. Impedance is 250 Ohm.
My question is: what is correct Phones setting for these headphones in TotalMix (for my UFXII)?
High or Low?
BR Stef
RME Fireface UFX II, RME ARC USB, ADAM Audio, Big Sur, DP, VEPRO, Cubase 13 Pro.
Re: Beyerdynamic DT 990 Pro - correct setting
If it sounds loud enough for you on the Low power setting with the output fader up, then you do not need High power.
OK, thanks!
BR Stef
