Topic: MAC and Levels? Where to keep fixed at unity gain 0dB?
I am trying to ensure that I am not doing anything odd with levels on my MAC.
In Audio/MIDI setup I see analog outs 1/2, and Phones 3, 4 are set to 0dB, and in top right where there is a speaker icon, I see 3 bars/waves, which corresponds to the 0dB I see in Audio/MIDI setup.
In TotalMix I have 0dB on all middle row faders.  If I play a youtube video (whose volume is turned all the way up), such as a RME tutorial, in order for it to not be insanely loud coming through my Adam A7X speakers (which are already set to two ticks below 0dB), I have to set the hardware output fader in TotalMix to about -35 dB. This results in me hearing at about 70dB according to my SPL meter.
Is this to be expected, that with 0dB set at every point in the internal computer chain,  I have to turn down the hardware output fader so much just to hear at reasonable SPL?
Just trying to ensure I don't have something odd going on in my gain staging...
Danke im Voraus
Re: MAC and Levels? Where to keep fixed at unity gain 0dB?
Yes, this is expected.
3
But can be optimized. There is no reason to not lower the sensitivity of the Adam's to minimum (pot at full attenuation). Additonally, if you have a Babyface Pro FS, there is a switch on the bottom  - set that to +4 dBu. Now everything should match much better.
If you bought an older model used you can add attenuators, see here:
https://forum.rme-audio.de/viewtopic.php?id=25399
