1 (edited by chrysalis99 2023-03-31 02:49:28)
Topic: Window Size on 3840x1620 Resolution Displays - TOO SMALL
Is there any way to make the contents in the TotalMix window larger? Of course I can drag the window out and make it bigger but the contents remain the same size. At the above resolution Total Mix is annoyingly small. It's only comfortably viewable at 2560x1080 but then my main DAW screen and any additional windows take up too much screen real estate.
The only work around I've come up with is offloading TotalMix to my iPad which works but Id like to keep my iPad in use for other duties and not dedicated to Total Mix only.
I searched the forum and didn't find an issue like mine and was surprised which makes me think Im missing something considering more people are probably using big displays with these types of resoltions now.
My Hardware:
MacBook Pro 2021 M1 Max
LG 34" 5120x2160 resolution
MacBook Pro Max M1
32GB Ram, 2TB HD
UCX II & 802 FS via OWC Thunderbolt dock.
DAW - Logic
Re: Window Size on 3840x1620 Resolution Displays - TOO SMALL
going off memory here but there should be a way you can view TMFX at 200% and maybe more? probably need to try in settings or look in the manual smile
-Steve
in the manual for my UCXII on page 80:
25.11 Menu Window
Zoom Options 100%, 135%, 200%, 270%. Depending on the size of the monitor and the cur-rent resolution TotalMix FX might be much too small and the controls too tiny to easily operate them. Together with the 2 Row mode these options give a lot of different window sizes that suit all monitors and resolutions currently existing.
4 (edited by chrysalis99 2023-03-31 02:54:45)
Thanks for pointing out that section of the manual! I found the setting for it!
MacBook Pro Max M1
32GB Ram, 2TB HD
DAW - Logic
