1 (edited by drifter7508 2023-04-01 16:51:11)
Topic: FF800 Midi out setting resets in Ableton 11 after restart
I noticed a weird thing: Ableton 11 is not saving the Midi out setting for my FF800 card.
After restarting the interface the midi out setting is lost.
All other interfaces settings are saved. Also Midi in settings for the the FF800 are saved.
Any ideas on what is causing this?
iMac Pro, Monterey, Ableton 11
Re: FF800 Midi out setting resets in Ableton 11 after restart
Problem solved.
If you turn off the sound card before closing down Ableton the setting is not saved.
Close Ableton first. Then turn off the FF800.
Thanks for reporting back.
