Topic: Matching sample rate to source
Using ADI-2 DAC FS
I listen primarily to music streamed via Spotify on my iMac via the DAC to Shure SE846 in-ears.
The standard macOS utility program "Audio MIDI Setup" allows me to specify the output "format" - i.e., the sample rate. I can select any one of several sample rates from 44.1 KHz to 768 KHz. The DAC detects the selected sample rates.
What I can't figure out is what the optimum sample rate should be for this source.
If Spotify is offering "CD quality" (and I'm not entirely sure that it does) then, presumably, 44.1 KHz would be fine and anything higher than that would be pointless.
Any guidance would be appreciated
