Topic: M1610 Pro
Hi, i can't seem to find clear specs on the dynamic range of the 1610 pro AD and DA converters, how would it compare to the ADI8 QS ?? i would like to move into AVB for a number of reasons.
Re: M1610 Pro
https://docs.rme-audio.com/m1610/020-16 … ls/#210-4R
compare to page 42 of ADI-8QS manual.
IMO the most important difference is that the 8QS has a +4.2 dBu setting which gives you a higher DR at those low output levels. If you use +13 dBu or higher, it doesn't matter.
