Topic: No signal with UCX II
Hi, so i lately updated to Fireface UCX II from Babyface Pro. Digicheck is worked very well with Babyface, zero issues. Now with UCX i dont get signal to Digicheck in any way. I have latest drivers and really dont know what is the problem. Im not a pro with totalMix but I've gotten it to work before with Babyface no problem. Any ideas ?
https://imgur.com/a/hIgBxcW
https://imgur.com/a/udG9mBe
Re: No signal with UCX II
Why do you post a DigiCheck screenshot where you assign a HDSPe MADI card instead of the UCX II?
Your UCX II (according to your TM FX screenshot) has no input signal coming in, so you won't see something in DC unless you change to Playback channels instead of Input.
I dont have any other option there to assign what i think its weird. There is no option for UCX II.
https://imgur.com/a/rtSsPYZ
4 (edited by waedi 2023-04-15 01:11:36)
You can't select UCX directly but you can select audio channels.
Input channels or playback channels.
You already have activated a Loopback of your music, the Loopback signal is on Input channels 9/10.
You did select input channels 1/2 but there is no signal.
Select input channels 9/10 probably you will have signal there.
Otherwise select "Playback" instead of "Input" for the source.
There is the music on channels 1/2.
5
You can not select ASIO Driver Fireface USB? Then it is not installed, or outdated. Current version is 1.227.
Is that the latest DigiCheck 5.96?
No, only option is "ASIO Hammerfall DSP". I have latest 1.227 driver installed. Digicheck is 5.96.
