Topic: Recommended Ref Level when plugging PH 1/2 to powered speakers?
Hi! So is there a recommended Ref Level I should use when plugging PH 1/2 to powered speakers through an insert cable?
Thank you!
RME User Forum → ADI-2 & 2/4 Pro series, ADI-2 DAC series → Recommended Ref Level when plugging PH 1/2 to powered speakers?
Thank you!
Usually Lo-Power (or IEM on 2/4 Pro SE and DAC) is more than sufficient.
But- just switch on “Auto Ref Level” and ADI-2 will always give you the best fit.
Turn down the speakers’ inputs as much as possible.
