Topic: Get/set/check settings via USB?
Is it possible to get/set/check settings of the ADI-2 Pro via USB? I mean for things that are normally controlled via buttons or knobs on the front panel, e.g. "Ref Level", "Trim Gain", or "Balance"? I may install one of these in an inaccessible location, and would love to be able to load/verify settings via software.
I may even be willing to write software for this, say using libusb, if a control interface is available.
Re: Get/set/check settings via USB?
Not possible, sorry
Previously not possible, but fortunately it is now! The new firmware with midi interface lets me send and receive settings from the command line with `sendmidi` and `receivemidi`. I can write a script to put my unit into a repeatable known state. Awesome!
You can use ADI-2 Remote App.
The app controls everything you can do on the device itself.
It‘s running on Mac, PC and iPad.
For a defined state you can load a prepared setup.
