BoooM wrote:Meanwhile I got galvanic isolation for USB, that helped tremendously. Haven't checked unbalanced since then on my studio setup. I can't think of it being advantageous if balanced is available. You even can run non-shielded balanced cables which you probably shouldn't do unbalanced.
That’s a possible reason:
PC’s, via the USB path, can spill a lot of audible and inaudible garbage into the signal path.
ADI-2 by itself, internally, is perfectly immune to this.
All garbage is kept on the outside.
You will never have any loss of audio quality on headphones plugged directly into it, no matter what happens on PSU or USB side.
Power- and headphone-amps connected to ADI-2 externally is a completly different story:
On unbalanced interconnects the cable’s shield is shared for a double-porpose:
(1) Shielding from electric stray fields.
(2) Providing the common ground reference for the audio signal, which incorporates running possible noise garbage to the next device.
While (1) usually works quite well, (2) incorporates a big problem, if noise and hum currents that origin from mains power and USB run through this shield:
Due to the voltage drop at the cable shield’s impedance of typically ca. 1 Ohm a noise signal develops, that fully adds to the audio signal.
The best known of these effects is the hum, caused from the so called “ground loop”.
Less obvious are distortions from high frequency intermodulations:
As power amps have a limited “speed”, they cannot handle the mentioned USB high frequency garbage, they can distort if they don’t use proper filters at their input.
This distortion “demodulates” the primarily inaudible high frequencies into the audio band.
If you ever heard the “tock, tock, tock...” from a cellphone spilling into the stereo just before it rings- thats such an effect.
Furthermore the HF saturates the power transistors, preventing them from doing their audio job properly.
With balanced interconnects audio and shield are separated, which circumvents those detrimental effects.
