Topic: Clock Digiface Dante to both external MADI and Dante
Is it possible to have the Digiface Dante sync to both an external MADI clock and separate external Dante clock? When I use it in standalone mode can it do a conversion to go from one clock to the other? I have a Dante network where the Digiface is not the master clock and I’m trying to use it to get a MADI device onto the Dante network. The only issue is that it’s hard to get a clock to the MADI device because the Digiface supports either MADI or word clock only on the BNC terminals so the MADI device is using its own internal clock.
Thanks!
Re: Clock Digiface Dante to both external MADI and Dante
The MADI device needs to sync on its MADI input. Can't believe it can't do that.
The MADI device only outputs. It has no input. It has a word clock though to take word clock input.
