Topic: ADI 2/4 PRO SE Question - Mixing input sources
Is there any way to mix two different input sources with the ADI 2/4 PRO SE? I know it doesn't have TotalMix so unlikely, but this would be such a useful feature to have, if at all possible.
RME User Forum → ADI-2 & 2/4 Pro series, ADI-2 DAC series → ADI 2/4 PRO SE Question - Mixing input sources
Do it in your DAW.
I'm not using a DAW. I have a music streaming going in thru USB and my PC's playback via SPDIF. Would be awesome if I could listen to both at the same time without switching inputs. Since this has a sample rate converter, maybe it would be possible. Just an idea for the geniuses at RME.
The usual way is to get a small RME recording interface to get TM FX and connect the ADI for monitoring.
https://www.tonstudio-forum.de/blog/Ent … ort-DE-EN/
https://www.tonstudio-forum.de/blog/Ent … our-Setup/
