Topic: Best cable from Eversolo DMP A6 streamer
Hello. For the best sound quality from Eversolo DMP A6 streamer.. what would be the recommended cable: USB, or coax, or optical?
Many thanks!
https://www.zidoo.tv/Product/index/mode … 3D%3D.html
https://www.zidoo.tv/Attached/image/20230220/20230220142413_71693.jpg
Re: Best cable from Eversolo DMP A6 streamer
based on the spec, all (usb, spdif, coax) should work.
Many thanks!
USB can transfer the higher sample rates, up to 768 kHz.
Only if you have audio files with native sample rates this high, USB is the best choice (server-internal upsampling doesn’t count).
Optical - my first choice - has the advantage of galvanic (electrical) isolation, which can avoid some problems in certain configurations with other devices connected to ADI-2.
Optical can transfer up to 192 kHz sample rate.
