Topic: Level meter gets stuck with a sub-bass EQ band
The dB number in hardware output channels drops down but finally gets stuck at a certain number after audio stops playing. It's more likely to happen if there's an EQ band is about 20 to 40Hz, with extreme gain settings. If there is no EQ, the dB number can drop to UFL as it should be.
My device is Babyface Pro FS, maybe it's a bug or some limitation of the DSP. I can tell my guess: Low frequency EQ'ing causes long ringing, the ringing tail is cut, leaves a DC offset.
Could anybody reproduce it or have any opinions? Thanks a lot.
