1 (edited by NL440 2023-06-15 00:05:54)
Topic: A possibly tricky one: Muting a specific output when on Speaker B.
This is the last thing I need to set up for my Monitoring situation, and I'm stumped:
When I switch to Speaker B I would also like to automatically mute the analog stereo output (5/6) that my subwoofer is on -- Speaker B is small speakers that I don't want to hear the sub on. Is there a way to do this using Speaker B, or would I need to create a different way?
Re: A possibly tricky one: Muting a specific output when on Speaker B.
Storing snapshots and select them from ARC would be a possible way.
3 (edited by NL440 2023-06-15 00:17:04)
Agreed, yeah. The only thing is I would need to hit another button to go back to the original Snapshot, instead of just a toggle key like the Speaker B switch. Thought there might be a way to do it with the Speaker B switch somehow, too, so I can use that button for it on the ARC.
The Assign of the main-out is stored within the snapshot.
Use two snapshots where the main-out changes its assign from speaker A to B and mutes the sub.
In the preferences of Totalmix there is a setting for snapshots - "do not load Mainvolumen".
Then your mainvolumen used via ARC should persist.
Just did that. Thanks for the help! I will make the normal "Speaker B" button the Mute button.
Glad you can make music.
Sheere endles possibilities for your desire.
