Topic: HDSPe and logic pro x latest edition
I'm trying to set up the HDSPe. I see the RAYDAT HDSPe in the audio preferences in logic and in the Audio midi setup. But in the total mixer I don't have a signal in the middle row of the mixer. And there is no sound recorded in logic. So what's the issue here? The sample rate is right, the channels are put in mono.
Is there a specific video or manual about the set up for  mac - audio midi setup - logic - HDSPe total mixer
I'm using the RAYDAT 22820116 REV. 1.0 version 4.24 with the latest version of logic and macOS Monterey
2 (edited by waedi 2023-06-15 20:12:30)
Re: HDSPe and logic pro x latest edition
In MacOS Preferences Audio have you selected the RME for input device and for output device ?
Then in Logic select System Audio for input and output device.
Thanks, yes it is. I even checked all the wires from da converter to Yamaha console….
Everything should be wired and installed in the proper way…
4 (edited by waedi 2023-06-16 15:19:27)
If you play something from the computer, not from Logic, from Finder or internet, Youtube or so,
is a signal then showing up in Totalmix middle row ? Should be the first channel from left...
