Topic: Streaming bridge for ADI-2 DAC
Ask for good and proven input for a streaming bridge for the ADI-2
I stream TIDAL and I prefer this app rather than some app with less features that links to TIDAL.
Some say Raspberry PI ?
Could an IPAD Pro connect (successfully) to the ADI-2 - or must it be a laptop with wired net ?
Re: Streaming bridge for ADI-2 DAC
iPad Pro: no active adapter, just a simple USB-B to USB-C cable or connector adapter
Page 52 user manual of ADI-2 DaC tells everything in details
3 (edited by artburda 2023-06-27 18:49:13)
Have a look a the Wiim mini and Wiim Pro streamers. They support Tidal Connect.
4 (edited by KaiS 2024-04-03 15:26:56)
I do use an older iPhone, having it dedicated for streaming Tidal.
Just needs an Apple CCK adapter and USB-A to USB-B cable.
iPad works great either.
WiiM Pro via coax S/PDIF. Set it to fixed output and it shouldn't mess with the bits (unless MQA is involved... sad).
See here for bitrate support depending on the path: https://faq.wiimhome.com/support/soluti … -supports-
6 (edited by Kjetil200 2024-04-03 12:42:30)
Sorry for occupying this thread, but I think it has relevance to this. I recently bought a ADI-2 fs dac and I’m currently using Roon on my old Mac to stream from Qubus.
I sold a Linn Klimax streamer after buying the RME
Is it possible to stream Qobus directly to the RME from an iPad if I buy the camera adapter from apple?
Any reason this would alter things sonically or resolution wise opposed the the Mac?
If I touch my Mac’s power inlet I sometimes hear a hum, so I believe it isn’t the most quiet one.
7 (edited by KaiS 2024-04-03 15:43:34)
iPad and iPhone (even the older ones like iPhone 6) works great with ADI-2 here, up to 192 kHz sample rate, the highest my Tidal account offers.
Depending on the iDevice model you need the Apple CCK (for Lighning models), or no adapter, just an USB-C to USB-B cable.
No, RME BitTest passes, so 100% signal integrity.
The reason is a lack of electrical ground connection in your system.
You probably have all 2-prong-only mains connectors.
If it bothers you, it can be solved, else just leave it.
Currently the best advice is, get an ADI-2/4 Pro SE PSU, it has a “soft ground“ configuration to deal with this.
Thank you! I will try the iPad solution for simplicity.
