Topic: Feature request ARC/TM: Larger volume steps to speed up the encoder
I'd like two more options for the Default Encoder Function:
-Volume Main (1.0dB)
-Volume Main (1.50dB)
Now there's only 0.5dB + 0.1dB
To drive through larger volume ranges you have to crank quite a bit, even with the 0.5dB setting, one or two bigger values would help a lot.
