Topic: Fireface UC - Digital Noise/Hiss Issue
Hello all,
First time poster and I am hoping that somebody can help!
I own a fireface UC and I have been having issues regarding noise/static/hiss in the past month or so. For info, I have owned the Fireface UC since 2014 and I use Logic Pro X. The unit has been well looked after and has not had any bumps or bangs. I have not changed the USB cable since purchasing the UC.
The noise/hiss is in the higher registers (10000 Hz +) and this happens when I use my both my outboard pre amps (Focusrite ISA 2 & UA 6176 into the UC’s balanced line inputs) or the Fireface UC’s own inbuilt pre amps.
When looking at metering, the noise floor is sitting mostly around -90db RMS, with the pre amps enabled, but this is without instrument connectivity. This will rise to around -80/-70db and sometimes more when I plug in a guitar (DI’d) or mic etc…
My buffer size is at 128 when recording and my sample rate is at 44.1.
Any help would be much appreciated.
Joe
