Topic: Noise issue when put on standby
I am using ADI-2 DAC FS.
ADI-2 DAC FS is disconnected from the PC and the power plug is also unplugged. So when I connect ADI-2 DAC FS -> line cable (VOVOX) -> speakers, I get a not so small volume noise from the speakers (not very loud noise...)
Then, after connecting the power plug to ADI-2 DAC FS, PC -> USB cable -> ADI-2 DAC FS -> line cable (VOVOX) -> speakers, and then starting ADI-2 DAC FS from standby mode, there is no noise problem at all.
So I am thinking that there is a problem with the ADI-2 DAC FS itself that is causing the noise problem, but what do you think?
VOVOX is non-shielded, so there may be a possibility of noise problem there, but I think VOVOX is irrelevant, because when I connect everything and start ADI-2 DAC FS, the noise problem does not occur.
To begin with, is there a constant noise when ADI-2 DAC FS is put into standby mode with only ADI-2 DAC FS -> line cable (VOVOX) -> speakers connected?
By the way, I don't know if this is related, but I am currently in the process of buying new line cables and only have one speaker connected!
Please let me know if you know of a solution, thank you in advance.
