Topic: How to activate a Phantom power on an input channel when in DAW Mode
first, this is my first message , so hello
How to activate a Phantom power on an input channel when in DAW Mode ?
I have a digiface USB and I want to activate the phantom on one input ADAT Channel...
I am in DAW MODE ...
Thank you
Maggiau
Re: How to activate a Phantom power on an input channel when in DAW Mode
What is the Mic preamp that you are using? The Digiface USB does not have any mic input.
ok Thank you... I will go through a preamp :-)
Then you activate it on your preamp and not through TotalMix which will have no idea of the status of your preamp.
