1 (edited by sami sanpakkila 2023-08-30 13:03:08)
Topic: Bit crushing noise with Fireface 800 and DaviResolve 18.5 on my set up
I'm having a problem with the Fireface 800 and Davinci Resolve 18.5 editing program mainly when I try to play back audio outside of Resolve. For example if I jump to Youtube to check something or preview an audio file in the Mac finder I get bit crushing noise on everything.
If I just stick to working inside Resolve and don't venture to play audio outside of it at any point or immediately if I quit Resolve the audio starts to work everywhere else as expected. Also if I change system output to monitor speakers instead of Fireface 800 there are no problems.
Routing the audio from inside Resolve to channels 3 & 4 in instead of the same 1&2 channels as the browser or finder uses helps a bit I think... but it doesn't completely fix the issue.
It's as if there's a conflict of bit rate somewhere but all my settings are 48kHz everywhere as far as I can tell. In Resolve, Total mix, Fireface settings... I've tried all the Resolve audio output settings but nothing seems to make much of a difference.
I'm using Mac Studio Max 1 with Ventura 13.4 (22F66) and RME Fireface 800 audio interface. I've been using this setup for over a year with no problems in Premiere Pro, Reaper and all other possible programs with no issues.
Any advice if there's a settings I'm missing would be most appreciated!
Re: Bit crushing noise with Fireface 800 and DaviResolve 18.5 on my set up
Did you try play around with the buffer size numbers in DVR ?
Yes I've tried most of the settings, but it's really hard to say if they make a difference. At least none of the settings get completely rid of the problem.
Sami
4 (edited by oli77sch 2023-08-30 21:14:39)
So the issue is related to DVR as it seems.
Do you have any other devices connected to the FF800 over ADAT / SPDIF / AES?
Or is some video equipment involved in your setup?
How are the clock / sync settings of the FF800 look like?
5 (edited by sami sanpakkila 2023-08-30 22:10:19)
I have no other devices connected to RME Fireface. No special video devices, a Lacie 20TB Raid via Thunderbolt, second BENQ monitor via HDMI and a few hard drives connected to Mac Studio and a Studio Display.
Below are screenshots of all my settings. I've tried to fiddle with most of the settings without much success.
https://i.ibb.co/cgxrcg1/Screenshot-2023-08-30-at-12-48-45.png
https://i.ibb.co/v4kXn96/Screenshot-2023-08-30-at-13-00-21.png
https://i.ibb.co/0MbXT7B/Screenshot-2023-08-31-at-0-00-39.png
The Playback buffer size is set to 4096, if you select 128 ?
Can you select the Fireface as audio engine in DVR settings instead of 'system audio'?
I've tried most of the settings and they don't really remedy the issue, they might change how often the bit crush occurs but hard to say...
No, that's not possible. I can change the Input and Output device to Fireface 800 but that doesn't fix the problem.
It’s probably unrelated, but what are that 'USB audio codec 1 & 2' in the Audio-Midi-Setup?
I don't know... It could be a Mac OS thing? Or maybe something to do with some equipment I have like Wireless GO II that I plug in from time to time to unload audio. But not sure... At the moment I have no other audio devices currently plugged in to the Mac Studio.
I disabled all VST plugins inside Resolve and also changed the Monitor output audio output to Fireface channels 3&4 and turned down the "trim" to -1.0db. I can still hear the problem on/off but it's extremely rare now...
So these setting changes help with the problem but don't really completely fix it. It's a bit difficult to say for certain cause it's so time consuming to test. But I guess if it stays like this it's "good enough" for my purposes.
I'm still having this problem with the latest Sonoma update. I've noticed that it's not just one program but any program that is CPU and GPU intensive (Premiere, Resolve etc.) and is under a load it makes the other programs audio crackle and glitch.
Any idea where to look for solutions on this issue?
14
sami sanpakkila wrote:
Fireface 800 and Davinci Resolve 18.5...
...I'm using Mac Studio Max 1 with Ventura 13.4 (22F66) and RME Fireface 800 audio interface. I've been using this setup for over a year with no problems in Premiere Pro, Reaper and all other possible programs with no issues.
I find this statement confusing. This exact setup worked for one year and suddenly it doesn't? Without any changes? Seems quite unlikely. Something must have changed.
Or did you just start to use Resolve?
Hi Matthias
Yes, at first I only noticed the issue with Resolve, I have used Resolve for years but maybe not as much as at the time of writing my first post.
First major update I've done since starting to use this set-up was a week ago when I updated to Sonoma OS in hopes that would solve the issue but it did not.
I'm not at all sure what could cause the issue but like I said, now it is not only restricted to being a problem with Resolve but I hear it when using Premiere Pro as well.
Sami
16
You use the usual dongle parade to make it work? Did you try a different TB port?
Yes, official Apple Firewire to Thunderbolt 2 and TB2 to TB3 adapters. I tested yesterday and today with different TB ports and it made no difference.
I want to stress that this is not a major flaw and when I only use one program it is not present. I've narrowed it down to hearing it the most when I do CPU and GPU heavy stuff like render edits and while waiting venture outside of the program to browse videos on Youtube (which you probably shouldn't do anyways).
