Topic: Signal but no sound
Hello! I'm using Digiface USB together with Totalmix. Right now i get signal when i play audio from my computer but no sound from the monitors.
I've tried so many solutions but none of them work. What should i do?
//Alvin
Re: Signal but no sound
Hi
How are your monitors connected? To the headphone analog out or on one of the optical outputs?
In every case you have to route the signal within Totalmix. If you have it set to submix mode, click once on the hardware output you want to use for the monitors. Now open the software playback channel(s) you want to hear.
If you use one of the optical outputs, make sure to have the right protocol selected in the settings app, either ADAT or SPDIF, according to what the monitors can receive.
