Topic: Set Headphone Out as Mono
I am planning to use Xviv U4 with Babyface Pro FS. This product works on a single channel output. I need to use it on the headphone output. The adapter is single channel. To make it work, I need to set the output as Mono. But, I do not see any option inTotalMix to set the headphone output as Mono, so that both channels are mixed and sent to both channels. The only place it shows is in the Main Output. Is there a way to set headphone output is Mono?
Thanks in Advance..
2 (edited by waedi 2023-09-05 04:54:27)
Re: Set Headphone Out as Mono
The Software Playback Channels and the hardware input channels have a knob inside for setting the width.
1.00 is fully stereo, 0.00 is full mono and -1.00 is flipping the channels left -right.
A mono-switch function is in the Main-out in the controlroom.
You may assign the main to PH (headphone output) then you can use the mono button.
It worked. Thanks!
