1 (edited by Trap 2023-09-10 12:27:21)
Topic: Remote control Adi-2 DAC Fs
Hi, I bought the used adi 2 dac FS (AKM chip) and the seller sent it with two remote controls, the old one with limited functionality and the newer one with a greater number of buttons. He claimed he had never used them. The batteries are OK and on the newer remote control the green light flashes when the buttons are pressed. The DAC doesn't respond to any type of command... With manual controls it seems to work well.
I couldn't find anything about it in the instructions, did I miss some settings or does the device have some problem? sad
I updated the software successfully.
Thank you
Re: Remote control Adi-2 DAC Fs
The instructions are clear and include the setting in the menu that needs to bet set to On for the Remote to work. As this is a used unit update to the latest firmware, then perform a total reset (also in the manual).
https://www.rme-audio.de/downloads/adi2dacr_e.pdf
