Topic: RME Dante remembering IP settings on power cycle.
Is this possible? I'm quite used to terminaling and using the sudo ipconfig command, but it would be nice if it could be set permanently.
Re: RME Dante remembering IP settings on power cycle.
You first have to tell us what you do. In Dante Controller under Network Configuration you can configure an automatic IP adress or type in a 'manual' one. The first option requires your router to always assign the same IP. The second option is stored and handled within the Dante module.
