1 (edited by guttalaser 2023-09-20 20:23:53)
Topic: Newbie questions about HDSPe MADI
Hi, i'm an half-newbie (i had a FF800) about setting up an HDSPe MADI eco-system.
I'm thinking to setting up my la PC Daw and i want is top-notch in audio quality and ultra-low latency.
My scenario is:
- i want an HDSPe with DSP because the direct injection in the PCIe lanes and the zero latency with fxs for the performers (i.e. vocals)
- recording analog signals (both line and mic) so i need the right inputs (at least 4 mic, with phantom - and  with Z-input for instruments - guitars and basses - and a good bunch of line inputs for keyboards, guitar and basses emulators, virtual drums, ecc)
- recording VSTs instruments (virtual amps guitar and basses amps, lot of orchestral sample-based libraries... and apply vst fxs... with the near-zero latency)
- mixing the tracks ITB with vst plugins and recording and mixing OTB with a real digital mixer
- give to the performers (vocals and instruments) a personal-monitoring headphones
- have a good bunch of outs for at least 5-8 personal monitoring for the performers, some line outs for some fxs processors , some line outs for 2 or 3 speaker monitoring systems (with and without sub).
So the questions are, starting from an HDSPe MADI with DSP, what other updated RME peripherals i need?
What AD/Da converters?
What mic/line pres?
And... what is the best/more compatible PC motherboard for the latest i9 Intel processor... that work flawlessy with the RME eco-system?
Tnxs a lot in advance, i know that some things sounds a bit overkilled, but i'm an old 60y.0. tart and i want to spend the rest of my life making music with a TANK of pc system.
2 (edited by ramses 2023-09-20 22:24:31)
Re: Newbie questions about HDSPe MADI
I would start with a combination of UFX III and ADI-2 Pro FS R BE or ADI-2/4 Pro SE.
The UFX III gives you a good mix of different port types, MADI, and two already well headphone outputs.
The ADI-2 series of interfaces give you excellent features for monitoring and two headphone outputs as well.
I would recommend isolating the UFX III behind a USB3 PCIe card with a supported chipset. Then you are more independent, adding USB peripherals as you like without impacting the UFX III.
The Sonnet card with USB Type A ports and FL1100 chipset is known to work well and has driver support in Win10/11. I wouldn't be frightened basing the system on USB, with RME drivers it offers a great performance comparable to PCIe.
If you run out of ports you can connect further devices using MADI.
Some blog articles that I wrote some time ago which cover these topics:
The new UFX III and some pictures, also a diagram of my setup:
https://www.tonstudio-forum.de/blog/ent … iii-en-de/
Differences and features of ADI-2 Pro DAC/Pro FS (except the new ADI-2/4 Pro SE).
Good to get an entry about the advantages of these devices:
https://www.tonstudio-forum.de/blog/Ent … ses-EN-DE/
How to integrate the ADI-2 Pro series devices into your setup:
https://www.tonstudio-forum.de/blog/Ent … our-Setup/
An excel sheet comparing the different RME USB/FW/TB interfaces:
https://forum.rme-audio.de/viewtopic.php?id=35156
A large "artificial" Cubase project as performance benchmark. 400 tracks / 803 VSTs.
Runs without audio drops at the lowest ASIO buffersize at single and double speed on my system,
which is basically from 2014, with a few upgrades... Same good performance as RayDAT PCIe card.
https://www.tonstudio-forum.de/blog/Ent … cks-de-en/
RTL comparison of different RME solutions that I owned / tested:
https://www.tonstudio-forum.de/blog/ent … cts-en-de/
My current setup:
https://www.tonstudio-forum.de/attachment/3044-current-setup-ufx-iii-v002-jpg/
UFX III also used as parallel effect loop for stereo setup of combo amps and two  Lexicon PCM as external FX 100.
Lexicons can be used for a) Marshalls, b) Cubase, c) PCM81 for Marshall and PCM91 for Cubase  (simply by different routings).
FC-300 for FX selection, tap tempo, etc ... and a MIDI splitter to distribute the Tap Tempo via MIDI to the two PCM's ..
https://www.tonstudio-forum.de/attachment/3059-2023-04-30-22-40-56-current-cabling-marshall-parallel-effect-loop-etc-jpg/
The rack with Thomann Eco rack, 23 cm depth, the Lexicons need more.
As I have no active cooling 1 RU more to have some space between devices for better airflow.
https://www.tonstudio-forum.de/attachment/3039-06-rack-front-jpg/
Amps recorded with 2x2 Mics, in most cases standalone with DURec, using UFX III as tape deck.
Reamping possible, because I plug guitars in the very good Instrument (Hi-Z) inputs of UFX III.
Rack tuner on top of left amp .. had one analog port free on the UFX III, so I can see / check tuning at any time.
https://www.tonstudio-forum.de/attachment/3040-07-fx-and-amps-jpg/
If you need more flexibility in placement of the UFX III and other components ..
I am using two Startech active USB3 extender which work fine.
Then you can have even longer cables than 3m in total, two of such extenders can be cascaded.
Setup for you could be e.g.:
PC---USB---ARC USB
| USB3
UFX III-----------AES or ADAT or SPDIF--------------ADI-2 Pro FS R BE----- monitors
          \------ 2 headphone outputs                                               \--------  1-2 headphones
The ADI-2 Pro has a SRC (sample rate converter) built-in which can be useful to add devices with fix sample rate
If you want to record / digitize Vinyl, then consider getting the ADI-2/4 Pro SE.
First, Ramses, let me tnx you so much for your reply with tons of useful infos!
BUT i must to say that your reply totally bypasses the mandatory "pillar #1" of my concept:
I want a HDSPe PCIe card with on-board DSP FXs... and THIS is my starting point.
So - then - what i need to know is what other RME components i need for the given scenarios (mic pres, line ins/outs, AD/DA converters... etc.).
Anway, tnx a lot.
For the inputs :
https://www.rme-audio.de/12mic.html
and for outputs :
https://www.rme-audio.de/m-32-m-16-da.html
Are you aware that the onboard DSP is a closed system, not for VST plugins ?
Sometimes people think DSP means it can load VST plugins and VST instruments...
5 (edited by ramses 2023-09-21 08:36:38)
Anway, tnx a lot.
No, I didn't bypass your requirement.
I think there is a misunderstanding from your side. The built-in DSP (for FX) is no FX accelerator.
The FX quality is good, but for the usual work, mixing and mastering, you will need either VST and/or external FX.
BTW, the UFX III has the same FX chip like the HDSPe MADI FX.
On the PC you have meanwhile such a processing power, that it is better anyway to use VSTs on the PC. Side note: also UAD recognized slowly that customers are not willed anymore to pay an enormous amount of money for their DSP boards with relatively slow Shark DSPs on it which act like a dongle for their VSTs and are still very limited in terms of performance.
With RME the performance of USB based and PCIe-based recording interfaces is comparable.
So I did my best to save you some money by suggesting the UFX III, which gives you a good start.
You were missing to tell, how many ports of this and that you require.
So it was not doable, to find an exact matching setup, as the requirements for that were not 100% clear.
Maybe they are not yet clear to you and you need to find your way ...
Therefore, one reason more for me to propose you a solid base with UFX III.
In combination with the reference converter not only to make your monitoring path superb in terms of quality and features, but also to give you two more extremely powerful and versatile headphone outputs.
My proposal is to start with such a setup and then you will see, whether you really need more mics or more analog ports for connecting external devices. The MADI port of the UFX III gives you the possibility to connect AD/DA converter and Mic Preamps as needed.
The UFX III has very similar Mic inputs like the 12Mic, also with 75 dB gain range, so you can make good experience with it.
And the UFX III has the excellent AKM converter of the older ADI-2 Pro FS. So they are  a) fast and b) have an excellent quality.
I think I made some good thoughts to propose this setup to you. You start with definitely less money, but get a very round setup to gain experience. Once you are sure what you require more, then add additional devices.
6 (edited by ramses 2023-09-21 07:29:48)
You can use a Mic Preamp as A/D converter, but it would be better to get an A/D converter supporting different reference levels.
Also for operational reasons, the Mic inputs might be in use, and he wants to work with external gear, maybe FX, compressor, EQ and what not.
Therefore, he would most probably need three devices with a HDSPe MADI FX: 12Mic and M32 Pro II AD and DA.
Together with an HDSPe MADI FX we talk about a huge amount of money.
Next, he also wanted headphone outputs. The HDSPe MADI FX has one older design, the 12Mic has also only one. So you have only two, this is another advantage of my proposal/setup, you get already 4 high quality phones outputs and with a 12Mic on top, maybe in the future, you have already 5. Or add an ADI-2 Pro and you get two more high power outputs. You have one AES and two ADAT/SPDIF ports free for that purpose.
Therefore, I would advise to start the way I proposed and to gain experience what exactly is require and in what port quantities (in terms of Instr Inputs, Mic Inputs, AD/DA for external devices, MIDI, AES perhaps for a reference converter, etc).
For the inputs :
and for outputs :
There are newer more recent models available than those...
Hi Ramses,
excuse me for the lag in the reply and tnx again for all your infos.
Ok so, for clarify, i know what Totalmix FX and DSP card mean in the RME world... i.e. i know is not like the UAD accelerator of proprietary VSTs.
I mentioned the VST (instruments and fx plugins) to evidentiate the needs of the lowest latency possible (kind of "zero latency", i know is not possible... but the less the better!) using software VST fx plugins and software VST instruments (i.e. using guitar/bass amp VSTs i need the smallest buffer possible - say 64 or even 32 samples) with no crackling! Same if i want to offer to a vocalist some vst fxs for his best perfomance).
That's why a PCIe card is the best/fastest way: direct injection lane into the CPU (my world is Windows, so i don't want struggling with the USB Windos mess!).
I'm an old tart and i'm studying for my maybe last PC-daw and sound interface solution and i want a no-brainer solution: JUST MUSIC and RECORDING and MIXING.
That said... yep i'm landed into the your above quoted lines: HDSPe plus the 32AD and 32DA (maybe the latest version) and a 12Mic, all in the MADI realm.
My last doubt  is: how can i connetc 3 external units (32AD + 32DA + 12Mic) to the HDSPe card? Is MADI a cascade connection?
Tnx again for your help.
8 (edited by ramses 2024-01-02 13:41:45)
MADI devices can be connected either as single device to a recording interface or can be chained, one device after the other and back to the recording interface. Each device in such a chain needs/introduces a few samples delay for the forwarding of audio packets. Look into the Octamic XTC manual, there the delay is mentioned. 3 samples per device at single, 6 samples at double speed.
Regarding FX. In TM FX, every channel has EQ and dynamic section, but when it comes to delay and reverb, there is only one FX bus for that. What you can do is to use it like a send effect in a DAW and dial-in the amount of Reverb/Delay that you want from this send effect, but you can't use it as an insert. There you have 1 setting for all channels.
Regarding USB … It is not as inefficient as you think.
1. compare RTL, there is only a little difference between PCIe card plus separate converter
2. Look at my last posting, where 99-100% CPU utilization still doesn't cause an USB based recording interface to break.
https://forum.rme-audio.de/viewtopic.ph … 92#p210092
You might have even more advantages by buying an UFX III.
Because this flagship interfaces might give you already all the ports that you need.
Plus, feature wise Autoset and DURec (as standalone or backup recording).
By Firmware upgrade, you will even get a Room EQ and Crossfeed. See the Posting about the Beta SW.
Even a UFX II without MADI might be sufficient, but if I were you, I would spend the extra bucks for the UFX III to be on the safe side, that you can expand using MADI if you require. Or to be able to connect an UFX III to HDSPe MADI FX, to be able to do that (whether it makes really sense or not).
In the old days when I was new to RME I also thought, that getting a RayDAT PCIe card and connecting an UFX to it would give me benefits in terms of latency. But this was not the case, it made it only harder in terms of operation and routing because I had to route all channels over ADAT and at the end to operate two different devices in two TM FX instances.
When you would connect HDSPe with UFX III via MADI, which would be possible, you would have the same operational "challenges" … to operate a HDSPe in one TM FX instance and the UFX III in the 2nd one.
Gent, sorry, but this is all too complicated. I would only connect an UFX III to a HDSPe MADI FX if I had it anyway and would like to use it solely for backup recordings.
But please do not make things too complicated.
If I were you, I would start with the UFX III and make experience with this USB3 based interface 1st.
You can still buy an HDSPe MADI FX on top whenever you like if you feel that you "NEED" to have it.
Regarding M32 converter and 12Mic. May I ask whether you REALLY need this number of channels? For recording a little and mainly listening to music, mixing and mastering an UFX III should be perfect. Now, even with Room EQ.
12Mic and two M32 AD/DA converters is around €9500 alone .. There should be a justification for this add-on cost.
So, could you kindly tell me how many analogue ports and what types of ports you really require?
Maybe we should start 1st to gather your actual demand.
A friend of mine just built a studio, and he has plenty of hardware FX (EQ, Compressor, Mastering devices .. Around 16 external devices). For him, an extension with an external AD/DA converter with 32 channels connected via MADI made absolutely sense. Also connected a 12Mic to connect all the mics to record the drum kit if his son.
But if you do not have this high demand for channels, I would try to reduce the setup to one or two devices like e.g. UFX III and maybe, if you like the features, the ADI-2 Pro FS R BE or perhaps ADI-2/4 Pro SE on top *roughly spoken* to just give an idea.
But now please let's talk about your setup, what ports are your real demands … Do you use external FX … etc?
What is in use now, where exactly do you feel a limitation?
Thanks for further information.
Thank you sooo much Ramses... and happy nu year!
Your answer cover my other today post that... guess what ... was exactly about using the HDSPe Madi as a main "port" and the UFX III as a satellite for I/O and AD/DA.
I'll follow your advise about starting with the UFXIII that make way more sense at least as a "roadmap" to follow.
The only thing i can't understand is why connecting both via madi is a challenge because two TMfx; in my mind the UFX III connected via madi is seen as a bunch of I/O in the only one TMfx related to the HDSPe... no?!
Tnx again Man
The difference.
If you connect external MADI devices to either UFX III or HDSPe MADI FX, then you see the additional ports of external preamps or adda converter as MADI channels in the ONE TM FX instance.
With two recording interfaces you have two TM FX instances, either in one or in two windows (TM FX: -> open new window).
But there is no backplane between them.
So you need to route channels between either ADAT and/or MADI.
Assumed the HDSPe MADI FX would be the main interface then the UFX III can either operate in standalone mode. But then it is cumbersome to operate things like Autoset or Mic gain.
So it would be better to connect also the UFX III via USB simply for operation.
Now the downside, you have to control the routing in two TM FX instances to route on the HDSPe MADI FX audio channels to the UFX III .. and also in the UFX III instance to route audio channels to the HDSPe MADI FX.
And this can become a little cumbersome.
Its easier to work with one card as then it is also easier to create submixes in submixmode.
A very nice setup could be this
PC--- ARC USB
| (USB3)
UFX III
| (AES or ADAT)
ADI-2 Pro FS R BE ----------- Monitors / Phones
alternatively: ADI-2/4 Pro SE which also has input for turntable
Also nice, integrated SRC (sample rate converter) just in case you have connected a DAT, which can not change sample rate and can not act as clock slave.
12 (edited by ramses 2024-01-02 17:48:09)
Another idea, not sure whether you have a similar environment like me, where the PC is also the audio player
++++++ Living Room ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++
ARC USB        Internet (DSL 250/45)
|        Fritzbox
PC with MusicBee Player Remote Plugin                    Wireless
|  +connect external FX like Lexicon Reverb unit if you need something like this
UFX III---------------------------------------------------------<-----ADAT1/2----->(2 cables)---------------------------+
ADI-2 Pro FS R BE        |
+Geithain RL 906        |
+Audeze LCD-3        |
                                                         HighEnd HiFi-------ADI-2 Pro FS R BE-----Optosel 4:1---Ch1-----------+
                                                         "Main Out B"        Ch2----TV
        Ch3----BluRay
Features:
- you can use your HiFi as 2nd pair of monitors for A/B listening
- High Quality D/A conversion in Recording Corner and at the High End HiFi with two ADI-2 Pro FS R BE
- Remote Control of MusicBee Player with Android Phone or Tablet via Wireless
- PC as Music Player using lossless FLAC files
- ADI-2 Pro features: Dynamic Loudness and Auto Ref level
               - using Bittest to ensure lossless audio transfer end to end
               - SRC if you have to integrate e.g. DAT recorder
               - if you want to integrate turntable, get ADI-2/4 Pro SE for the HiFi corner
- Oehlbach Optosel Mk II 4:1 switcher up to 192 kHz, you can switch between 4 ADAT/SPDIF sources
   has a nice remote control, looks good, also operateable at the device with one push button to switch input channels
The difference.
Ok, so if i'm understanding correct: if i connect via madi to the HDSP Madi Fx whatever madi device that is ONLY a converter or an I/O/mic preamp hub then  i'll see those channel in a single instance of the TMfx that is related to the HDSP Madi Fx, BUT if the madi device connected to the HDSP Madi Fx is a recording device like the UFX III then i'll deal with two distinct (even in the same windows) TMfx panels and the things became very complicated (routing etc...) RIGHT?
About the your other answer... well my search is for the lowest... lowest... let me say... lowest overall latency possible (my main instruments is guitar and i use lot of viryl software amps emulations, and the feel of the guitar playing needs the lowest latency, even less - say - than a synth or keyboard... so... if - like you say -  the UFX III is fast enough (and the pc too: i'll build an i9 14900k based pc on an Asus ProArt motherboard with ddr5 ram, so i think fast enough)... i'll record with the best low latency... so i don't need to overcomplicate the project.
Tnx again for your patience with me Man!
14 (edited by ramses 2024-01-02 22:10:20)
I am playing guitar as well.
I have meanwhile a stereo setup with two Marshall combos, I think you saw that already in the picture above.
I used the UFX+ some time ago, since a couple of months I upgraded to an UFX III to also have fastest converters available.
To be honest, calculate it through ... on stage you have more latency between musicians .. that only as a side note.
I am using the UFX III for special purposes, e.g. as a parallel effect loop for the Marshalls to keep the punch of the signal, I do not like to noodle the sound completely through an FX unit ...
Signal flow: I plug my guitar to the INST input of UFX III.
From there, the signal goes through a booster pedal (Marshall Guv'nor) and further to the amp input.
From the left Marshall combo, the preamp out signal goes back into the UFX III and from there
a) straight into the two power amps (L+R)
b) to one of the two connected Lexicon PCM 81 (or alternatively the PCM 91)
The 100% wet FX signal coming from any PCM I add to the submix which goes to the poweramp section of the combos.
Finally, the two amps are being recorded by two mics on each amp (Tube Mic and SM57).
I never had any latency problems because the routing happens on the device itself. I do not route through the DAW.
From the DAW I only listen to the backing track to which I play and this I record.
This setup is absolutely no problem, no PCIe card required, it wouldn't change anything much.
The other advantage of this setup, I can record the direct signal from the guitar for re-amping purposes.
Lately, I got the hang of playing through a very nice amp VSTi. I can tell you that I have no lag playing even when using ASIO buffer sizes up to 128 samples. Even 256 would be possible, tried it in the past already. But in fact this is not required to have such big buffers. Usually, I use 64 or 128 samples. And this setup rocks...
Another advantage, by TM FX routing capabilities, I can use the two FX (PCM81 and PCM91) for either guitar or DAW or PCM81 for guitar and PCM91 for DAW. All is possible.
Two sound examples: see on this page: https://www.tonstudio-forum.de/blog/ent … iii-en-de/
Really, you do not have to worry about anything, it simply works. The new UFX III has converter with a very low latency. It also worked very well with the previous version, the UFX+, which had a little slower converter. I repeat: on stage, you have more latency between musicians than that. Take an Excel sheet and do the math yourself.
15 (edited by ramses 2024-01-02 23:00:52)
BTW .. in this Excel I calculated e.g. latency differences between UFX+ and UFX III, the latter has very good AKM converters from the ADI-2 Pro Series. Now look, how low the effect of converter latencies are:
The pure converter differences:  6,7 cm (9 samples)
                   The RTL difference: 15,4 cm (20 samples)
Would you ever think about optimizing any playing latency by holding your ear directly in front of the speaker grill of your Marshall stack? No...
https://www.tonstudio-forum.de/attachment/3094-13-2024-01-01-latency-differences-ufx-and-ufx-iii-jpg/
And if you compare now RTLs at 44.1 kHz with an ASIO buffersize of 64 samples of a) HDSPe MADI FX and ADI-8 QS via MADI (a little older converter) and b) UFX III
a) 4,095 ms
b) 4,444 ms
The delta is 4,444 - 4,095 = 0,349 ms … in this timeframe, sonic moves 12 cm through the air.
This difference you will already have when turning your head while playing.
To sum up, save the money, you do not need a large and expensive MADI environment for your application.
I can still play in tune if the RTL is at 13,6 ms (ASIO buffersize of 256 samples at 44.1 kHz)...
There is plenty of headroom...
https://www.tonstudio-forum.de/attachment/3028-rme-rtl-comparison-v2-jpg/
a) 4,095 ms
b) 4,444 ms
Yep gotcha Man!
I'll go for the UFX III
My latency reference for guitar through VST amp is Leon Todd (you know... one the best guitar stuff youtuber). I was in touch with him about his system setup for vsts amp demo and that guy was so nice to answer me that he use Apollo interface setted at 48khz and 64 samples with about 4ms of latency (but in a Apple domain). So to me 4ms with vst amps and some fxs is the latency goal.
17 (edited by ramses 2024-01-03 07:03:49)
Up to 10 ms RTL you have absolutely no issue, in a normal band context with up to 10m distance between musicians you have much more latency, or imagine a whole orchestra.
I know Leon, a nice guy doing some interesting videos. But you should distinguish between his setup and requirements for playing, recording and mixing. And to be precise. His sound is mainly from his fingers and playing style and phrasing, not because of 4 ms RTL. Even at 8 ms, he wouldn't sound different and the playing over an VSTi wouldn't feel different.
Check it out yourself in a blind test with another person. With >10ms, which is e.g. 13.6 ms (ASIO buffer size of 256 samples at 44.1 kHz) you get slowly a certain feeling of a delay. Up to 128 samples buffersize at single speed you are IMHO absolutely safe. And if you like …  Use 32 samples if your PC is fine and if your DAW project is not too complex.
I would stay at least at 64 (or 128) to have a little more headroom when playing through VSTi.
As a side note … Did you notice … the above values are all at 44.1 kHz, which is the "worst case"? With higher sample rates, the converter latencies decrease a little, and you get even a little lower values … But at the end of the day, the ASIO buffer size is the dominant factor.
So when comparing Leon's values at 48 kHz, then you should compare this to an UFX III at 48 kHz. My numbers above are at 44.1 kHz because this is the normal sample rates for CDs, I, personally, stick to 44.1 kHz. 48 kHz is usually more in use when doing videos. But you can use whatever you like. You can also record at double speed if you prefer.
In the UFX III manual chapter 40.2 you see converter latency in the chapter about latency and monitoring, then you can make your own calculations. The difference is not much, but there is a little difference.
https://www.dropbox.com/scl/fi/2qofbn0f4oyab6s9tqi7q/2024-01-03-fface_ufx3_d.pdf-ch-40.2-Latencies.jpg?rlkey=oxvjsyujwjonn4m4kfy6npg8n&amp;dl=1
18 (edited by ramses 2024-01-03 11:38:03)
Other topic, regarding instrument inputs and the very nice RME conversion quality, some sound example:
a) straight into instr input, no VSTi, no processing
This is a Gibson L5 CES from around '71 directly plugged into the instrument input without any VSTi and without any form of post-processing. Fully improvised, simply the guitar to a backing track from a friend (Wesley G.):
https://www.tonstudio-forum.de/attachme … -320b-mp3/
[ taken from this blog article: https://www.tonstudio-forum.de/blog/Ent … CIe-EN-DE/ ]
b) silent recording, guitar mic'ed
This is an overdub through my Marshall Combos, silent recording with volume peaks under 80dB.
UFX used as a parallel effect loop (Guitar being plugged into the UFX's Inst input). Fully improvised:
https://www.tonstudio-forum.de/attachme … orrow-mp3/
[ taken from this blog article: https://www.tonstudio-forum.de/blog/Ent … -DURec-DE/ ]
c) Guitar via VST using an external FX unit (Lexicon PCM 91, connected to UFX III)
And this playing through an VSTi (S-Gear 3) and using Lexicon PCM 81 as external FX. Fully improvised over Backing Track from MusicBee Player (lossless FLAC file), loopback recording of the UFX III headphone submix with WaveLab Pro:
https://www.tonstudio-forum.de/attachme … part1-mp3/
https://www.tonstudio-forum.de/attachme … part2-mp3/
[ taken from this blog article: https://www.tonstudio-forum.de/blog/ent … iii-en-de/ ]
19 (edited by ramses 2024-01-03 07:46:18)
My devices are connected like described / attached in the blog article about the UFX III, which I referenced above already:
Also cool the little device where I can split the midi control of the foot controller to two PCM's .. to distribute the TAB tempo to the two units. Switching between the two PCM's and different amount of FX "wet level" by using different TM FX snapshots (routing). Easiest to be switched via the nearby ARC USB.
The PCMs can be configured to stay at the tabbed tempo when changing effects. All in all, very useful.
Ramses, let me say how kind, generous and full of infos you are Man!
Just from the first answer till now!
Thank you so much Man to spend so much time and patience with me, you are a real resource of this forum!
Now i have a much more clear idea for my project!
I'll go with the UFX III that packet all the i/o type, converters, on board function (DURec, standalone) and even the MADI for future expansion (one other idea is to add in future an hardware digital mixer like the Midas M32 Live and a pair of digital stagebox via cat5 cable and connect the mixer to the UFX III via madi to get an hybrid software/hardware recording system).
Thanks again from Italy my Friend!
You're welcome :-)
