Topic: Best option RME ADI-2 Pro FS R Black Edition or Fireface UCXII?
Hello All, I am new to the forum, but decided it would be good place to ask fellow RME users before embarking on a purchase!
I primarily want to upgrade my studio converters for mixing and mastering purposes. Secondly, I will need to do some vocal tracking and also require a good headphone amp.
I currently use an Apollo Twin duo (mk 1) which is connected to my Audient Nero monitor controller -whereby I can switch between two sets of monitors (Neumann kh80's and Yamaha NS10's). I use the Apollo Twin when recording vocals.
I initially was going to upgrade to the Apollo Twin X, but have seen so many reviews stating that the RME conversion and pre amps are far better, so I think its certainly worth my consideration, but would like to know exactly how I could incorporate either option within my current setup?
I am considering either the RME ADI-2 Pro FS R Black Edition or the RME Fireface UCX II, But would greatly appreciate some advice.
The reason for me considering the RME ADI-2 Pro is for the superb conversion quality! As mentioned above during mixing and mastering, but also due to the superior headphone amp, which I require to drive Neumann NDH 20 and Sennheiser hd650 headphones. However, I don't know for sure, if this is the best option?! I wonder if you could answer a few questions:-
1.Is the ADI-2 Pro conversion superior to that of the Fireface UCX II?
2. And if so could I use my current Apollo Twin to record vocals into ADI-2 Pro for e.g? If so what would be the best way to do so?
3. Should I go with the Fireface UCX II and omit the Apollo Twin completely? (This is only conditional if the Fireface will not compromise conversion and headphone amp as this is primary reason for upgrade).
4. With either option what would be the best way to connect to Audient Nero?
It would be great to hear from you all!
Thanks in advance:-)
