Topic: Limitation of PEQ Treble (Band 7) at 10khz
I was playing around the filters and found this PEQ curve to compensate the high roll-off
https://forum.rme-audio.de/viewtopic.php?id=26952
Since I used all 5 bands on Room correction and only have the Treble (Band T/7) available which can go as high as 10khz, wondering if we can extend the treble range up to 16.5k? So we can you it for the compensation curve?
Thank you
