Re: Connecting RME Fireface 400 via ADAT issues.
Yup, understand that.
By default it's assigned either to AN1/2 or Phones depending on selection on device.
BF is in normal mode (not CC).
Instruction says:
Switch Output Routing (Playback)
Use Select key and select “Phones” --->I have it but since it's connected via ADAT, Sync is also light up but I guess it doesnt matter.
Push and hold the Encoder until either the right or left level meters run up. -->does not happen, when I hold it meters are blank, when i release it only Dim lights up and that's all.
Left meters: Copy mode. The signal of output 1/2 is also routed to channel 3/4 and channels 1/2 of the
ADAT/SPDIF output. Right meters: DAW mode, output routing 1:1. -->no meters light up.
Still how to assign knob directly to AS1/2?
