Topic: E-Drums connected directly to MIDI on UFX III
Brand new owner of an RME UFX III in my home studio. Installed it 2 days ago and I'm very impressed with the sound quality it delivers. I am in the process of integrating analog hardware into my workflow and I have a Ferrofish Pulse 16 MX connected to UFX III via MADI.
Anyway, my question is about MIDI. I have a Roland TD-17 electronic drum kit that is about 18ft away from my PC. I currently use a Roland USB - MIDI device that connects my TD-17 to my PC via USB. I use Superior Drummer 3 drum samples to play so I need the absolute lowest latency in order to record drums and have drummers not feel like there is a delay between hits and sound. With my previous interface I could get about 7ms RTL.
Would it be better to connect the Roland TD-17 module directly to the UFX III MIDI port ? Instead of using the USB-MIDI interface ?
About 6 months ago I purchase a MIO XM (iConnectivity) device to route MIDI over Ethernet.. but I spent a lot of time trying to make it work and it just did not want to work.. at all.. so I abandoned that and got the Roland USB-MIDI device. Just want to know if connecting directly to UFX III via MIDI would give me lowest possible latency, and still enable me to route to Superior Drummer 3 in my DAW (Studio One 6.5).
Thank you !!!
Stephane
