1 (edited by robj232 2023-10-23 14:54:20)
Topic: TotalMix Fx Presonus Studio Channel
UCX II
Windows 10
Last night I pulled out my Presonus Studio Channel. I connected output of the studio channel to balanced line in 8 UCX. Line input of Studio Channel into output 6 of UCX.
My goal was to process already recorded audio. For the unprocessed track in Cubase my input was 8 and my output was 6. I heard playback in TotalMix Fx, but no processed sounds while dialing anything in on the studio channel. Am I missing something?
Re: TotalMix Fx Presonus Studio Channel
Did you the routing in Totalmix from Software playback channel 6 to the hardware output channel 6 ?
May you add a screenshot of your Totalmix while music is playing ?
I did. I’ll add a screenshot here in a few when I give it another try.
4 (edited by robj232 2023-10-23 16:22:22)
Here is TotalMix and Cubase routing.
https://ibb.co/3f3cd51
https://ibb.co/3Cgjh6D
5 (edited by oli77sch 2023-10-23 16:31:56)
There is a signal visible on input 8 in Totalmix, so far all seems to be fine. A Cubase issue then …?
(EDIT): ah, you should create a new track with input 8 (and of course NOT output 6 to avoid a feedback loop), then enable software monitoring. Or you could use the function or plugin for external processing. I don’t use Cubase, but there is such in most DAWs.
6 (edited by waedi 2023-10-23 16:31:27)
You are most probably monitoring the output signal of Cubase but not the return signal from the Presonus.
In Totalmix the fader of input 8 is all the way down, pull it up and you will hear the Presonus sound on the main out (where your monitor speakers are connected ).
I tried it in Cakewalk as well. Im wondering if there is something wrong with the Studio Channel. The front meters move, but if i crank the gain/or level up I dont hear a boost in volume. Im not hearing anything from the knobs.
Have you monitor speakers connected to the interface or do you try to listen with a headphone ?
Did you try pull up fader 8 ?
I’ll try that and and make sure input 8 is routed to the main outs. I am only hearing signal coming from Cubase and it’s not in any way processed
10 (edited by waedi 2023-10-23 19:54:39)
sure the bypass buttons on the Presonus are not pressed ?
In the Totalmix photo you send the Cubase signal directly to the main-out and no signal from the Presonus to the main-out.
Unless you change this, you will hear the dry cubase signal only.
11 (edited by oli77sch 2023-10-23 20:11:51)
To find out if the Presonus unit is working properly or not, I would suggest to connect its outputs directly to your speakers.
EDIT: I meant the output to one of the speakers since it’s a single channel device …
That worked, but there is still some strange issue. It is only coming out the main on the right side. here is a pic
https://ibb.co/8DyMb6S
The input channel in Totalmix has a wrenchtool symbol, click it, it opens the channel and a panorama knob shows up
14 (edited by oli77sch 2023-10-23 21:13:20)
No, there are no hidden pan knobs. But in the screenshot the mono hardware output 8 is selected.
robj232, click on the main out channel strip, the view changes for the mono inputs and you will have the pan knob then.
https://ibb.co/FHwtY7M
https://ibb.co/NV8J9p3
I don't know what I did, but I fixed it. I saved a snapshot. Thanks for all your help.
Have you seen my screenshots?
17 (edited by robj232 2023-10-23 21:52:09)
Ah, that makes sense. I was wondering what was going on when the pan knob disappeared. When I fixed it I did click on the main and clicked the mono button, then back off. So I was somewhat close. Thanks
