1 (edited by mindburner 2023-11-15 16:13:35)
Topic: getting digiface SPDIF to show up
hi all
I have a digiface interface with 4 AD front ends coming in from my many old analogue synth.
This works great for recording audio but my DAW MIDI sucks
It's sloppy compared to say a standalone unit like a AKAI Live II and so I have been looking for a solution.
expert sleepers do a silent way SPDIF and midi expansion unit
My question is..
How to I get the SPDIF option to appear in Cubase?
I have all but one of the outputs from the digiface used with the AD frontends
I have changed the output on this one from ADAT to SPDIF but don't see it in Cubase
I just want to check the expert sleepers stuff will interface with the RME before I shell out the cash
any help most appreciated
https://www.dropbox.com/scl/fi/tomc9ft6xptov4agdhroc/madiface.JPG?rlkey=oce2p2kzf94797g7kos2kxpj2&raw=1
https://www.dropbox.com/scl/fi/hzhuyh1lk5vhd46d1j0ej/digi.jpg?rlkey=87yy32snbzjc1r0rn5rpk18eb&raw=1
https://www.dropbox.com/scl/fi/77fxrfdr28ts1vq4jid3r/cubase.jpg?rlkey=zsvandhxeenztwop6pa80obnd&raw=1
Re: getting digiface SPDIF to show up
It won't change/appear in Cubase, just choose the first pair of each ADAT set.
Thanks very much.
Yes I was able to try a small SPDIF to analogue audio converter to check that I was able to get audio from Cubase by assigning the first pair, 25 and 26 outputs
That means I should be able to drive the expert sleepers VST program and therefore the ES-40 hardware
appreciate the help and sorry for the noobish question. I just have always used straight audio through ADAT and though SPDIF was just not showing up
Alan
