Topic: ADI-2 Pro FS BE. Balanced Headphones + SPDIF out volume control?
Hi all,
I have a ADI-2 Pro FS BE with a balanced headphone connected through the front 2 jacks and and which works brilliantly. Rear main out 1/2 are now auto muted but that's fine as I have nothing connected there.
Now I have bought 2 Neumann KH120 II active near field monitors, which besides an analogue balanced XLR in have a SPIF RCA in. I have connected the Neumanns with the ADI-2 through the break-out cable RCA SPDIF out.
Now the issue... I tried to read the manual over and over but I just can't figure it out. When I hooked up the Neumanns I had FULL VOLUME out through the SPFIF and as you can imagine, not ideal.
The manual says to set the option Digital out source to "Main out" to send the processed main 1/2 signal to all the digital outputs so I've done that. The thing is, when balanced headphones are connected you can not adjust the volume of 1/2! It just says BAL on the bottom on the screen... Presumably as the rear main 1/2 are muted anyway.
I CAN adjust the volume of main 1/2 out when I remove the headphone plugs and the unit disables balanced mode. So currently I can have either balanced phones working OR SPDIF working with volume control.
Again, I don't mind if the analog main 1/2 out are auto muted, what I would ideally like is:
1) Balanced headphones working, with volume control, though the front jacks, and at the same time
2) Active digital speakers working, with volume control, through SPDIF.
Apolgies if it sounds confusing, hope it makes sense what I'm trying to do here. Any gurus out there who can help me out please?
