Topic: Digital cracking/interference sssue with RME HDSPE AES soundcard
**Issue with RME HDSPE AES soundcard
Hello, I have been having issues with this soundcard for sometime now. I have been through at least 3 soundcards (The same make and model) and getting no where.
I have changed PCI slots/changed every setting possible on Total Mix & Hammerfall/updated firmware but still getting cracking popping issues.
This is being ran though a HP EliteDesk 800 G4 WKS TWR on Windows 10 22H2 and outputed to a Yamaha PM1D via AES3 and shares the Word clock from a rosendahl nanosync.
It picks up 48 from the rosendahl nanosync so it's not a clock issue.
I have ran this through a Redbox AES3 - analogue converter into another mixing desk and still the same issues. I have tried different AES3 outputs too on the D-sub out on the both cards.
Has there been something I have overlooked?
Here is the a video demonstrating the interference. It's not intermittent and only happens during playback.
https://www.youtube.com/shorts/IJtWpkDHBx8 - Tone
https://youtube.com/shorts/bkdZ1bNIzqY? … GrA11RmyFw - Music
Has anyone dealt with this sort of issue before? Is there a fix?
Re: Digital cracking/interference sssue with RME HDSPE AES soundcard
You can test the card alone by looping an AES signal from the output to input.
Play a sound to the output and record it with the AES card on internal clock source.
- Are there any click or pops on the recording?
Furthermore check your PC with Latencymon: https://www.resplendence.com/latencymon
How to use: https://www.sweetwater.com/sweetcare/ar … cy-issues/
and: https://www.sweetwater.com/sweetcare/ar … -fix-them/
Audio AG Support
