Thanks for the answer! But it doesn't work in my situation. After uninstalling and reinstalling new card drivers, rme total mix does not open. The icon is present on the panel but it does not open and there is no sound.
I also have a question...my motherboard has a built-in sound card...should I install drivers for it and not use it? I noticed that after installing the driver for the built-in card and not using it, the sound of the AIO pro is much better and cleaner. What is this connected with?
I also noticed that including the .wav file once, it sounds clean in Windows Media Player. If you immediately run the same file again, the sound becomes flatter in stereo...On the third play of the file, the sound becomes clear again[clean and dynamic as when you first turned it on]. What is the connection with this alternation of sounds every other time? Thanks.
