Topic: UCX II Is it broken on arrival? [HELP]
I bought my UCX II a few months ago but haven't had time to use it. But now i REALLY need to use it, I'm having really weird technical difficulties.
PC: mid 2014 Macbook Pro
OS: macOS Big Sur (11.7.9)
Headphones: Audio-Technica M50x
DAW: Reaper (temporarily)
Driver: v4.08
I'm connecting my microphones to MIC/LINE 1 and 2, and the corresponding analog 1 and 2 channels (which i've separated into mono channels on totalmix) won't show anything input coming in from the microphones.
When I connect my guitar to the LINE INSTR. 1 and 2, the corresponding analog 3 and 4 channels (also separated into mono channels) show input coming in from the guitar. I've tried hearing it through the headphones without any luck. I recorded the input that comes through in reaper and what came out was a very concerning glitchy version of what i played that cuts out and sounds heavily distorted.
When I connect my guitar to MIC/LINE 1 and 2, I also don't get any input coming in from the guitar.
I've tried different guitars, mics and cables and thinking seems to be working. Should I be contacting RME becasue my unit is broken? or am I just doing something wrong?
2 (edited by waedi 2023-12-13 02:21:04)
Re: UCX II Is it broken on arrival? [HELP]
May you provide a screenshot of Totalmix ?
Have you opened some input gain ?
For condenser mics the 48V was ON ?
The firmware is up to date ?
1. yeah I'll post some screenshots below, i opened the settings for the channels being mentioned too so you can see them.
2. Yes I've tried increasing the gain on all inputs, on 1&2 it does nothing at all and on 3&4 it just makes the distorted and glitchy sound louder and more distorted and glitchy.
3. I only have dinamic mics.
4. I think so, I will add the firmware version onto this thread tomorrow... But I installed the drivers and totalmix just a few months ago - and i was already experiencing these issues... I tjust hought it was because I needed to learn how to use the interface and totalmix.
What else could this be? I'm absolutely gutted.
https://imgur.com/7kH3EaS.png
https://imgur.com/llV4vDw.png
https://imgur.com/75Nx2kh.png
4 (edited by waedi 2023-12-13 06:40:48)
All gains are fully closed. Not good.
AutoSet does reduce the gain when needed but not open.
You have to open the gain to a good value.
Especially the dynamic mics need a good gain at least 12 o clock when not 3.
I would set it to maximum and activate AutoSet
5 (edited by vonhart 2023-12-13 07:41:32)
I'm sorry, perhaps my screenshot confused you, but you're misunderstanding. In the screenshots I have the gain down, but like i said before, I have already tested turning the gain knob up (to the max) and it didn't change anything at all.
It's not a matter of the volume of the input being very low, it's that it is inexistent whatsoever, regardless of how much I turn the gain knob or any the risers up.
There's also simultaneously the issue with the guitar line instr. channels and the messed up audio they produce.
i tried some more and still nothing. rebooted, etc. i might try another computer if i can.
if anyone has any ideas they would be more than welcome.
The front display of the unit shows also no input signal ? Then the unit should sent in for repair.
Contact : support@rme-audio.com
yes, correct. ok I'll try there then.. i was just wondering if maybe I was missing something.
Thank you.
9 (edited by waedi 2023-12-14 03:09:57)
Sure the mic is working ? Testet on another equipment ?
Hopefully you use the XLR inputs for the mics, not the TRS?
I already said i tested it with two different microphones, they both work fine on a new interface i had to get from a different brand for a project. I'm pretty sure It's the interface.
