Topic: UFX II can't be recognize on Win10
OS version : Windows10 22H2
Hardware : RME UFX II
My PC can't recognize madiface_usb driver after I installed ASIO4ALL.
Not sure if there's a conflict between these two software.
After finding this issue, I uninstalled ASIO4ALL and reinstalled madiface_usb driver. But the problem is not fixed.
I tried that UFX II with my other PC and it works fine. So something must be messed up when ASIO4ALL is installed.
Is there any other method I could try before a full system reinstallment?
Re: UFX II can't be recognize on Win10
What exactly is not "recognized" where? If you are not seeing Windows Audio devices, check the number of active WDM devices in the settings dialog.
ASIO4All is not required, but doesn't do any harm, either.
