Topic: RME ADI-2. XLR & RCA Outputs.
Hi. I'm new to the group. Contemplating purchasing a RME ADI-2.
What I would like to know is can you use the XLR & RCA Outputs simultaneously.
IE: XLR to the Active's & RCA to the sub.
Thanks Andrew
RME User Forum → ADI-2 & 2/4 Pro series, ADI-2 DAC series → RME ADI-2. XLR & RCA Outputs.
Thanks Andrew
…can you use the XLR & RCA Outputs simultaneously.
IE: XLR to the Active's & RCA to the sub…
Yes, both are active at the same time on ADI-2 DAC.
XLR and RCA have the exact same signal quality.
Depending on the mains’ and sub’s models, using the sub’s low cut filters for the mains might make sense too:
ADI-2 DAC -> XLR or RCA cables -> [subwoofer in / filtered out] -> XLR or RCA cables -> main speakers.
