Topic: I'm curious about the application method of Steady Clock fs.
There is a steady clock FS function of ADI 2 PROFS, right? By the way, if UFX+ sets the clock with ADI 2 PROFS as the main, is UFX+ also subject to the steady clock FS?
Ucx II , Adi2/4 Pro Se, Drawmer 1970 , Lct 1040 , WIN11 , Ableton Live 11
Re: I'm curious about the application method of Steady Clock fs.
Steady Clock FS controls the internal clock of ADI-2, that is used for AD and DA conversion, to gain ultimate quality.
Devices connected to ADI-2’s digital outputs by AES / SPDIF Coax or Optical benefit from the jitter removal too.
Then, assuming that you connect with a device other than FS, can you say that other devices get all the effects of Steady Clock FS even if they are not FS?
4 (edited by KaiS 2023-12-24 10:38:54)
Definitively not all.
Any device works within it’s built in capabilities.
Feeding a lower jitter digital signal can improve it up to this certain point, not beyond.
There’s even a limitation of how precise a digital clock can be transferred over a distance through a digital interconnect.
RME converters from early on had very good clocking and re-clocking.
Steady Clock FS is the current culmination of this development, but older devices already are extremely good.
