Topic: 802.1AS device priority
using 12Mic, 12Mic is elected Grandmaster. This causes a desirable situation where 12Mic is Master for audio and gPTP clock.
However, when connecting some Apple Thunderbolt 2 Ethernet adapters to the network, the network elects new Grandmaster (newly connected MAC computer). This situation is not acceptable. Also it causes all other devices on the network to resynch to new Grandmaster causing audio interruption. This is also unacceptable as any computer reboots would cause entire audio network crash for few seconds.
How it is possible to modify 12Mic network adapter settings to set Priority 1 and Priority 2 parameters so that some network adapters would not cause Grandmaster changes?
P.S. While this would probably be a new feature you need to make, can you also make so that 12Mic could have Static IP settings?
