Topic: Multiface II (No Headphone Output Channels)
When switching the operational mode I can hear the headphones in Full Mode using the hardware mixer, but what I really want to do is assign in my DAW as the headphone output using DAW mode. I think the problem is that the headphones aren't appearing as seperate output channels in my MacOS Audio Midi Setup (see screenshot).
I can use the headphione output 33/34 from the Digiface just fine, but why don't the Multiface's appear similarly as 53/54. The manual states they should appear as 19/20 but I'm only getting 18 in total.
Anyone have an idea what is going on here?
From the manual:
"Channels 19/20 of the Multiface are available on the front via one 1/4" unbalanced TRS jack (stereo output). This output uses a hi-grade converter, therefore maintains a high signal to noise ratio and low distortion (THD+N)."
I'm on Ventura 13.6.3 with Mac OS X Driver V 1.12 - Multiface, Rev. 21
