1 (edited by yeahtuna 2024-01-05 13:47:24)
Topic: Issue adjusting Babyface Pro FS input levels of inputs 3/4 with MIDI
When sending CC9 (values 0-65) on channel 1 or 2, the respective input's gain is adjusted as expected.  However, when adjusting input 3 (sending CC9 on channel 3), the gain only responds to value 0-10.  Is this a bug?  I would expect inputs 3 / 4 to have the same gain resolution as inputs 1/2.
Re: Issue adjusting Babyface Pro FS input levels of inputs 3/4 with MIDI
They don’t. Take a look in TotalMix and you will see you have less options
I see.  Gain on input 1/2 goes up to 65, but inputs 3 / 4 only go to 10.  With my mouse, I can increment inputs 3 / 4 by 0.5db steps.  It's a pity that using MIDI we are limited to 1db steps on input 3 and 4.
3/4 are not microphone inputs, they do not provide the same amount of gain.
