Topic: Can I switch between snapshots? ARC USB and UCX II in standalone mode.
I seem to be able to adjust both my monitors and headphone volume in standalone mode. But I don't seem to be able to switch between snapshots.
Is this possible with the UCX II? I can see that you can do it with the UFX+ and UFX II.
All I want to be able to do is switch between my two sets of monitors and my headphones, and also adjust the volume of the chosen output.
Re: Can I switch between snapshots? ARC USB and UCX II in standalone mode.
Did you save the snapshot into the unit ?
...transferred into the Fireface via 'Flash current mixer state'
I hadn't, I thought when your stored snapshots, that stored into the UCX. I have now found that and can store it. Thanks.
This function is called 'Store current state into device -> Setup 1 to x'.
