Topic: [Solved] Main volume value -> save to snapshot?
Hi!
I have the old/original Babyface connected to my Windows 10 PC and today I updated the driver to the latest version, 5 years after the last update I did. So Totalmix was also updated, from v1.50 (2018) to v1.84 (2023).
In the old TotalMix I had snapshots, which still remain in the new version, but I see that the snapshots don't apply to the Main volume value (as they did before, in the old version). For examle, if I manually change the Main volume and then click on a desired snapshot, the Main volume value won't change to the snapshot's Main volume value as it did in the old version of TotalMix.
Is there a way that I could save specific Main volume values to snapshots like before?
Thanks in advance!
https://i.ibb.co/Snf5Lrz/totalmix.png
Re: [Solved] Main volume value -> save to snapshot?
In Totalmix settings is "Do not load main volume" active ?
Deactivate it.
That was it! Thank you very much! smile
